krobbe
Mar 08, 2013Explorer
Ok Bee. My 2009 has no leaks nor any sign of water damage around any slides or windows. If the slides leak, chances are the seals need replacing or some debris is interfering with the seal. Make sure the slide roofs are clean before bringing them in. Maybe the previous owner didn't maintain them. Your issue with a screw thru a wire causing a fire 4 years after manufacture could've resulted from a careless previous owner. And I think the slanted walls are great for seeing what's behind me while towing. Knocking down a TT because you didn't do your due diligence before buying is really just sour grapes.
