opnspaces
Apr 13, 2017Navigator III
Glad you got it apart and working enough to get on the road. Unfortunately no locking tab on the star wheel means no self adjusting brakes. When you get back from your trip pull each hub one at a time and make sure the star wheel is loose and can spin. Then put it back together and adjust the brakes up. I'll bet your brake controller is set too tight after adjustment.
