LVJJJ
Jan 29, 2018Explorer
Lippert frames
Been towing for 30 years, but never heard of a Lippert frame. Seems like most of the comments are negative.
So, what is a Lippert frame?
JCR-1 wrote:
I think most all these products today are welded by robots.. not unskilled laborers.. hence unemployment.
It's a frame made by Lippert Components Inc (aka LCI)
Well duh. I know it was a stupid question, but was wondering why they seem to be not so good, understand now.
Still have not heard if my Trail Cruiser is built on one, or how do you identify one?
Huntindog wrote:
I do not know what "rolled" means. I DO know what welded looks like. I have seen that on many TTs.
I DO NOT have a welded frame rail frame.
It is what I consider to be a "normal" I beam.
Ralph Cramden wrote:
Simply put there are two methods used to make a structural shape. Hot rolled or cold rolled. Specifically in relation to an H or I which are a complex shape, there are two ways to make them. Hot rolled is steel goes in one end of a plant, and an I or H comes out the other. Its then shipped to a fabricator who cuts it, drills it, fabricates it.
The other way to make an H or I, is you take 3 pieces of plate or sheet, and weld them together. That's it, two options. You can cold roll a C, or an angle, or a Z or a bar, and a lot of other shapes, but you can not cold roll an H or I. Those are the simple versions. This Article explains it better than I can.
That's why I think your main rail is an engineered / fabricated / machine welded shape. That is unless Lippert is having hot rolled shapes custom made at great expense, or own a hot mill and making their own. Not sure why they would want to. The size is not available unless its fabricated. Maybe I'm wrong.
sgfrye wrote:I gotta sorta agree with this. My Sabre has a stout frame because Sabre requested it from Lippert. Sabre is no longer in the TT business. Could be that they had a hard time selling them for enough to turn a profit with some of the upgraded stuff they were building.SoundGuy wrote:SidecarFlip wrote:
Build them cheap, stack them deep and build them with unskilled welders. Recipe for disaster.
Why would you expect anything else, after all YOU asked for it - "you" meaning you and I and all the rest of us who want as much trailer as we can get for as little cost as possible. That's the recipe for disaster. :W
X2 on this. in general the public who buy these products want cheaper prices on everything . in the manufacturing industry no matter what it is. appliances, autos, rv's the factors going into the retail price involve are complex but material cost, labor,advertising, warranty coverages are what sets the prices.
SoundGuy wrote:
My 2014 Coachmen Freedom Express has a pressed together Lippert frame that has cracked near the rear tires on each side. :M
As to the OP's question, my understanding is that newer models now use a different frame that shouldn't exhibit this frame cracking problem that have plagued so many Freedom Express owners.
GrandpaKip wrote:
If you truly believe this, then why in the world do you keep recommending this trailer?
SoundGuy wrote:
Surely this is self explanatory! :S
GrandpaKip wrote:
My apologies. However, your understanding is just that (an opinion). If you had stated when, where and what Coachmen had done, that would be fine for all the trailers that have been constructed since then. But the fact still remains that you have touted this trailer many times without caveat.
As I see it, the main concern would be with new members of this forum looking at used trailers. With your recommendation, they might be led to believe this is a great camper. A problem with cracked frames should eliminate this trailer from any consideration.
