LVJJJ
Jan 29, 2018Explorer
Lippert frames
Been towing for 30 years, but never heard of a Lippert frame. Seems like most of the comments are negative.
So, what is a Lippert frame?
SoundGuy wrote:SoundGuy wrote:
My 2014 Coachmen Freedom Express has a pressed together Lippert frame that has cracked near the rear tires on each side. :M
As to the OP's question, my understanding is that newer models now use a different frame that shouldn't exhibit this frame cracking problem that have plagued so many Freedom Express owners.GrandpaKip wrote:
If you truly believe this, then why in the world do you keep recommending this trailer?
Surely this is self explanatory! :S
SoundGuy wrote:SidecarFlip wrote:
Build them cheap, stack them deep and build them with unskilled welders. Recipe for disaster.
Why would you expect anything else, after all YOU asked for it - "you" meaning you and I and all the rest of us who want as much trailer as we can get for as little cost as possible. That's the recipe for disaster. :W
drsteve wrote:
The 2018 Coachmen in my sig has plenty of shoddy workmanship, the most serious being a floor that flexes and makes loud cracking sounds when walked on in front of the stove.
Ralph Cramden wrote:goducks10 wrote:Huntindog wrote:goducks10 wrote:Huntindog wrote:
My present TT has a Lippert frame. It is by far the best frame I have had under any of my TTs.
10" tall real I beam (not welded) 1/4" thick.
The welds are top notch, and the frame is powder coated.
Lippert gets a bad rap here, but my frame is proof that they can put a good frame under a TT, if the manufacturer is willing to pay for it.
I had a out of warranty problem with the Lippert sealed bearing axles my TT came with. Lippert had discontinued those axles, but made me a very fair offer to get both axles replaced.
They could have easily weaseled on me, but they stood up and did the right thing.
I know I may be a rare bird here.... But I am a Lippert fan
I highly doubt the web is 1/4" thick. If so that TT would weigh way too much.
The flanges would be 1/4" where they meet the web.
Just curious what TT do you have?
2010 Palomino Sabre. 30BHDS
The web and flanges measure 1/4 thick.
I am not set up to post pics. I do have pics of my frame on the factory floor. from when I toured the factory after picking it up.
Jbarca has seen them.
I don't BS about this sort of thing.
Well thats impressive.
I don't doubt the 10" with 1/4" inch flange and web thickness. I do however doubt it's rolled and not a machine welded / fabricated shape. The only 10" rolled shapes I am aware of that could be used in a trailer frame application would be an S10x25.4 or S10x35. Neither of those have a 1/4" thickness anywhere. The lighter 25.4 has roughly a 1/2" flange and a 3/8" web.
Ralph Cramden wrote:I do not know what "rolled" means. I DO know what welded looks like. I have seen that on many TTs.goducks10 wrote:Huntindog wrote:goducks10 wrote:Huntindog wrote:
gmw photos wrote:GrandpaKip wrote:
....snip...
Because some people have to try to convince others they are never wrong ?
"Listen to me, I am the truth, the light, and others will lead you astray"
Kip, a certain poster here has stated that yours truly is trying to lead others astray into dangerous territory. Oh my.
