FishOnOne wrote:
Cummins12V98 wrote:
I like the sound of my 15 pulling 33k combined in the mountain passes. Also taking off from a start in TH with the Aisin with light to moderate pedal when grabbing each year it sounds like the timing is advancing and gives a nice clatter.
You forgot to add that your B&W hitch also improves the sound too! :W
I have to say that the 6.7 CTD at idle sounds very quirky to the point it's sounds like there's a cork in the tail pipe.  Having said that, remove all the emissions stuff and it sounds like a sweet 5.9 CTD the way it should be.
Ok, since you mentioned sound.  The 6.0 and 6.4's had a very noticeable sound coming from the exhaust especially if modified.  Loosely place your lips together and blow air between them.  Yea that's the sound.
