- kaydeejayExplorer
colliehauler wrote:
Isn't that what "matching numbers" is all about when looking at collectors vehicles?kaydeejay wrote:
That's what I wondered about.
Don't Ford engines have a stamped serial number that happens to be the last six digits of the full VIN? - colliehaulerExplorer III
Don't Ford engines have a stamped serial number that happens to be the last six digits of the full VIN? - kaydeejayExplorerDon't Ford engines have a stamped serial number that happens to be the last six digits of the full VIN?
- path1ExplorerAre you sure vin number of engine? On my 03 f350 my 5.4 I've been asked for date of manufacture and once or twice asked for vin of truck itself for brake type related stuff. By vin number part guy looked up gvcw. Turns out brake lines come in different specs. Over a certain gvcw or below. Anymore at ORiellys I look at their computer screen for foot notes to make sure before buying. Not good for me but the heavier duty parts are usually special order and not in stock.
- colliehaulerExplorer IIIThanks for all the info.
- Tim_NowickiExplorerI was in the same situation with my v-10 F-450. Found a tag on the engine that stated "remanufactured for Ford" It showed year and month of remanufacture, part number, jobber number etc. I believe it was on the driver side attached to the block. Could view it from under the vehicle.
- kerrlakeRooExplorerI know the VIN can tell you a lot about a vehicle, and I believe engine size is among them, but the engines serial # I dont think is tracked that way. What you may be able to find is multiple engine #'s from the block as well as other parts, valve covers etc, and see if the numbers match.
Some of the ford truck sites delve pretty deep into the VIN data, you could start there.
Maybe one of these can help
https://www.fleet.ford.com/partsandservice/vin-guides/
https://www.ford-trucks.com/forums/vindecoder.php - colliehaulerExplorer IIIWhat I was trying to determine is if the engine has been replaced.
- K_CharlesExplorerThe V in VIN is for vehicle so why would an engine have a vehicle number.
I'm not sure what number you're looking for. - kerrlakeRooExplorerI'm guessing you mean the serial Number, look behind and below the yellow dipstick according to this.
https://www.google.com/search?q=ford+5.4+engine+number+location&sa=X&rlz=1C1GKLB_enUS626US626&biw=1280&bih=891&tbm=isch&source=iu&ictx=1&fir=DZR_1hqqECx5xM%253A%252CtHM3gshTP8d1ZM%252C_&usg=__oNi0BO3ExNFQFkJNGob9Tq-Ro_s%3D&ved=0ahUKEwiVkpz8jePbAhVD64MKHdqhBcAQ9QEIKTAA#imgrc=DZR_1hqqECx5xM:
