cartmancartman
Oct 21, 2016Explorer
I think there is some misconception of what I am talking about. You have part of the frame mounts that are bolted on and then you have a part that slides in and out and is retained by a simple pin which your tie down bolts on to. My concern is should these slide outs be removed each time to do this? I need to go underneath the truck on 4 sides and remove them each time. I will most likely get padlocks for them as it seems theft is highly unlikely but a small possibility.
INn regards to the fastgun lock set, I have to disagree, a good hit with a hammer should be able to knock them loose. I highly doubt the crooks had the ability to break into your truck, hot wired it and werent unable to remove 4 small locks, that seems highly unlikely. They probably left it for some other reason, I can be wrong.
I ordered the locks online and was greatly underwhelmed when they arrived. I can probably saw through them in a minute with a hand saw. They need to build a lock which goes through the hole and surrounds the entire fastgun IMO.
Thanks for all the responses.
