Reddog1
Oct 22, 2016Explorer II
cartmancartman wrote:If I were that concerned, I would simply replace the with a 1/4" bolt and a self-locking nut. If that would not satisfy my concerns, I would have the extensions welded on.
I think there is some misconception of what I am talking about. You have part of the frame mounts that are bolted on and then you have a part that slides in and out and is retained by a simple pin which your tie down bolts on to. My concern is should these slide outs be removed each time to do this? I need to go underneath the truck on 4 sides and remove them each time. I will most likely get padlocks for them as it seems theft is highly unlikely but a small possibility.
Wayne
