bowler1's avatar
bowler1
Long Bed TV as a Daily Driver???
I am getting a 5th wheel camper in the near future and will need a new truck to tow it. I am still debating over long bed or short. I see the advantages and disadvantages of both and am not biased one way or the other.
For me I think the biggest consideration is going to come down to use as a daily driver. I currently drive a Tundra. Moving to a Ford F-350 will mean the truck is going to be longer even with the short bed. Adding a longer bed will make it that much longer still.
I have never driven a long bed truck, but anticipate that it could be a PIA for maneuvering in a parking lot. But I am not sure especially now with all the backup and side view cameras. I also have read posts where people say its not any harder to drive than a short bed.
So while part of me says not to limit my capacity and go with the long bed, the other part of me is a bit leery of that decision because 95% of my driving will be as a daily driver. So I am not sure whether the extra capacity is worth any daily driving headaches...or are there really any more headaches for driving with the long bed.
thanks for your help
Matt
  • Your needs do not require a long bed. I have been towing several FWs, using 6'9" bed Ford trucks for going on 20 yrs. Fords axle center, to back of cab is about 41 inches. I've been using non-slider hitches with my Fords, and currently 1" ahead of axle center. With the newer contoured fronts on the FWs, a standard bed is a non-issue. Also most modern FWs have somewhat extended pin, adding extra clearance. You could hit the cab under the right circumstances, if you worked at it, even with a long bed. Just using common sense/awareness is required no matter what your towing, TT, boat, cargo trailer, or FW.
    Just another thought...a long bed crew cab truck will require more space when maneuvering/backing a FW, due to the longer wheelbase. My SC with 142" wheel base helps for this, and is also a very stable platform while towing.
    Jerry
  • get a little beat up 4 banger that get 30mpg for around town. and the tow truck that fits your rv.
  • I have the longbed and the benefits of more room, higher cargo capacity, and no special hitch required for clearance of the 5th wheel outweigh any slight issues with it being a little longer than a shortbed. It is my daily driver.
  • Long bed vs short bed, the question you REALLY need to ask yourself first is, what do I do with this truck when NOT towing? Do you have a real genuine NEED for the long bed if NOT towing? If so, then get the long bed. If you cannot find a true, justifiable reason you would consistently use the log bed for, then you have your answer... short bed.
