jonmad
Mar 20, 2015Explorer
Long shank question...
I would like to be able to drop my truck tailgate while connected to my TT. I have a long shank but was wondering if there is any reason not to use it?
jonmad wrote:
If you go to Amazon and search for 2" RV hitch shanks you will find some as long as 18".
4X4Dodger wrote:ScottG wrote:
Nope. I installed one that was several inches longer for the same reason on my Reece DC and had no problem.
A few years later my buddy got the same DC setup and the new shank (or drawbar) that came with it was longer just like the aftermarket one I bought.
Where did you find this Ball Mount/Shank that is several inches longer? I have searched the internet and stores from Tractor Supply to the Uhaul place to no avail. I have a class V Reese Titan and Reese does not make them in longer lengths. There are reducers but I want to stay with the 2.5 x 2.5 class V. I only need about three inches longer.
I do find all kinds of those crazy Rube Goldberg over complicated setups for sway control systems but I simply do not need that.
Any help will be appreciated. Otherwise I need to change the location of the tongue Jack.
wing_zealot wrote:The payload capacity does not change, but the further aft of the rear axle that your ball is located increases the weight on the rear axle, and further decreases the front axle weight more than a normal hitch setup. This is due to increased leverage on the rear axle.
Why should it? The payload capacity doesn't change if you are towing a 5th wheel (with the payload directly over the axle) compared to a TT (with the load out a ways from the axle). So why should it change if the load is at 36" away from the axle vs. 34"?
jonmad wrote:
Tailgate hits the tongue jack.
