Very good looking truck.
I found some small differences between my 2016 SRW and the new dually. Fortunately Torklift is using a different front tie down and no fish wire needed. I thinkk I posted this elsewhere, but get you a pair of small needle nose Vise Grips to hold the back up plates. And be sure you orient the drivers side right regarding the welded on nut. I just installed the BigWig I had on my previous truck. The hanger brackets on the frame are very close to some kind of electrical equipment. The brackets wouldn't fit "square" over the frame and are very close the receiver hitch. But otherwise the sway bar fits better and I was able to get it level without cutting the tailpipe.Yesterday I put my plywood flooring in the truck. The tailgate frame width is about an inch narrower than my 2016 was.
Start loading this morning for a trip to Heber Springs Arkansas.
We pass through Mississippi a lot. I'll wave at ya next time!
