poppin_fresh
Aug 01, 2013Explorer
Definitely be on the lookout for leaks around the bunk seals. I looked at Roo that had leaked so bad that whole bunk was soft. Its was only a matter of time before the people sleeping on it ended up on the ground unexpectedly.
You should also very carefully check out the roof. A roof that has been taken care of will actually look like its been touched up a bunch of times and that's a good thing. The caulking needs routine patching as it cracks over time. If you see large cracks/gaps you can probably be assured that it wasn't taken care of and water has made its way in. Not good...
