d3500ram's avatar
d3500ram
Explorer III
Mar 31, 2021
Looking for a better ride on the truck…
Many here may know that I sold my camper some 3 years or so ago. I had it all set up to haul and carry that weight. Now that it is used occasionally, sans the camper, I am noticing how rough it rides and want to do something about that.
First thing was to drop the air pressure down to unloaded specifications. I am even thinking of taking off the Rancho 9000’s and going to a more stock type shock absorber. I may go to a different tire, but these still have quite a bit of tread left and will consider a change on the next set.
But I think my best bet is to try to simulate what more comfortable riding trucks use for components. I think I might try swapping out the stock 1-ton rear leaf springs to 1/2 ton springs. I am sure a local spring shop could do this but not sure if the ride will be too soft.
I know everyone wants to “up” their truck to carry weight safely… since I do not have the camper, I want to do the reverse. I thought about going to half ton wheels but feel the swap to accommodate 5-lug wheels is too much work.
  • Sulastic hangers did make noticeable difference on my dually.
    It was still "truck ride" when empty, but I no longer panicked seeing street cover.
    I was concern about the life expectancy, but coming to 4th year, they still look good.
    If you think these 2 mods are even remotely feasible things to do, then you should re-consider your plans and be suspect of any "good" modification ideas you may come up with, going forward.
    Drop tire pressures to the min for weight. If you can't stand the suspension, off road fab shops like Carli and Thuren have very compliant spring packages. sky's the limit, or more accurately, your wallet is the limit.
    BTW are you saying you haven't dropped tire pressure from presumably more than you need? That's like a 5 minute exercise and free.
  • It seems you are trying to modify a 2005 truck. The ride on many older HD pickups was pretty rough. Newer trucks like my 2010 or my 2018 Ram are built for comfort and if anything have rides that are too soft. My sole modification on my current truck is the addition of Timbrens which are not engaged except when carrying a heavy load.
    For your old truck you already have the best modification, adjustable Rancho shocks. Dial the rear shocks down when not carrying a heavy load. You can tinker with tires and tire pressure but I doubt that will make much difference.
  • If they make Sulastic springs for your truck, try that. Lower the tire pressure even more. You probably can go down to 35-40 in the rear. Also, adjust the Ranchos down. I use to ride 1 in rear and 3 in front on my SRW.
  • Just do one thing at a time so you know what does the trick. Leave the Ranchos and just turn them down. Don't get rid of them. Try ditching the "custom overload spring perch spacers" in your sig, what ever they are?(I assume blocks that hit the overloads earlier/more?)
    Dunno what the ton rating of a wheel is going to affect, unless you meant tire?
