SoundGuy
Sep 14, 2016Explorer
lawrosa wrote:
I did a search and looked at contless manufacturer sites and can not find the right weight and floor plan for my newer 2006 silverado 1500..
The 06 silverado says payload of 1500 lbs. I did not get my max yet if I go by the axle weights. Which I do.
Ill have 600 lbs in cab and bed with camper stuff. Just sewer hose, alum jacks, pads, hoses, ect..
Im fine with a 7500 lb or less TT.
Towing 7500 lbs with a 2006 5.3L Silvy? ... thanks for my morning chuckle. :W Funny now, but not so much if you actually attempt it ... first tow and you'll be wondering what the heck you were thinking. :R No way, no how is this truck suitable for towing any more than ~ 6000 lbs fully loaded, particularly if it's running GM's ubiquitous non-tow friendly 3.42 axle. Having towed our 5500 lb (fully loaded) KZ Spree for 4 yrs with this same truck over just about every terrain one might encounter I wouldn't have wanted to tow any more. I replaced that truck with an Avalanche - same engine, same wide ratio 4-spd transmission that isn't anywhere near as capable as the current narrow ratio 6-spd, and same non-tow friendly 3.42 axle ratio. Our current trailer is 1000 lbs lighter, ~ 4500 lbs loaded and ready to camp, and even though my passenger load is lighter because it's now just my wife and I our Av does just OK and certainly wouldn't set any land speed records. Towing 7500 lbs? - not a chance. Not only is there insufficient grunt under the hood for this size of trailer but you'll run out of sufficient payload capacity to account for trailer tongue weight transferred to the truck l-o-n-g before you get anywhere near the truck's GCWR. Prove it to yourself - fill the truck tank, mount weight distribution including spring bars, and go weigh it. Subtract your weight from the scale reading and you'll have your particular truck's dead weight as it's sits there ready to be hitched to a trailer. Subtract that number from it's GVWR and you'll have it's actual, real world payload capacity ... and it won't be anywhere near 1500 lbs, guaranteed. Believe otherwise and you're dreaming. ;)
