54suds
Mar 07, 2018Explorer
I had the same truck 2008.5 duramax and carried a Bigfoot 3000 series c1002 fully loaded air, gen . 4 batt full refrig lots of extra stuff .it was in the 5000 lb range going down the road . Highly recommend large dia roadmaster anti swar bar,tork lift top mount stable loads use you air to adjust ( 5 to 12 lbs )how quickly stable loads engage the over load spring .
Lower stable loads can be used to further adjust ride & level
ps do you have a stock hitch or a tork lift i have a used tork lift 20 k one with a 36 inch extention hanging around here that I no longer use.
