- Bionic_ManExplorer
Me Again wrote:
FishOnOne wrote:
IdaD wrote:
I think I like the new Toyota powertrain the best for a half ton. Haven't driven one, that's just based on a few reviews and Toyota's reputation.
I would much rather have a GMC with a 6.2 vs the new turbo plagued ugly as sin Toyota Tundra.
Having said that I know someone who has a new 2021 Tahoe that had to have the lifters replaced due to a surging problem this year.
I am driving a Ford F150 because the GM lifter issues and Hemi cam issues.
The root cause for the Hemi cam issue is the lifters fail first and then take out the cam.- Me_AgainExplorer III
I am driving a Ford F150 because the GM lifter issues and Hemi cam issues. - Grit_dogTrailblazer
time2roll wrote:
wanderingbob wrote:
Dealer will gladly do it.
How would ya change out that lower belt?
Welp, if it's like every other LS motor I've worked on, remove the big serpentine belt and then remove the little one behind it.
Took me all of about 20 min to replace both belts, last time. (FWIW, they were fine, but 20 years old, replaced them along with a full maintenance on an old vehicle we bought)
The better question would be why is that a concern and how many serpentine belts have you actually had to replace in the last 25+ years? BenK wrote:
Movigng up to the +8K GVWR class has duty cycle come into play with these ICE's
Agreed, this is likely why we still haven't seen a gas engine with forced induction in a 2500/3500 series pickup yet. Ford has put the Ecoboost V6 in the Transit for some time, even the 11K GVWR version. So it's not impossible, although the Transit's GCWR is much lower than the pickup. It will be interesting to see if Stellantis uses the Hurricane engine for its 2500/3500 trucks, keeps the 6.4 Hemi, or drops the gas engine altogether.wanderingbob wrote:
How would ya change out that lower belt?- Grit_dogTrailblazer
BenK wrote:
Movigng up to the +8K GVWR class has duty cycle come into play with these ICE'srjstractor wrote:
LanceRKeys wrote:
Best in class towing? Isn’t the ford with the 7.3/4.30 rated higher than that? Or is this a half ton?
I believe it is for 1500 series trucks, GM's new 2500/3500 series gas engine is a 6.6. I did notice the caveat in "Best in class V8 towing". Among the big 3, it does have the best V8 tow rating, by a very small margin. What they left out is that the best overall 150/1500 series tow rating (only 400 lbs more) is held by a V6 with slightly more than half the displacement of the GM L87 V8.
Engrish prease? - BenKExplorerMovigng up to the +8K GVWR class has duty cycle come into play with these ICE's
rjstractor wrote:
I believe it is for 1500 series trucks, GM's new 2500/3500 series gas engine is a 6.6. I did notice the caveat in "Best in class V8 towing". Among the big 3, it does have the best V8 tow rating, by a very small margin. What they left out is that the best overall 150/1500 series tow rating (only 400 lbs more) is held by a V6 with slightly more than half the displacement of the GM L87 V8. LanceRKeys wrote:
I believe it is for 1500 series trucks, GM's new 2500/3500 series gas engine is a 6.6. I did notice the caveat in "Best in class V8 towing". Among the big 3, it does have the best V8 tow rating, by a very small margin. What they left out is that the best overall 150/1500 series tow rating (only 400 lbs more) is held by a V6 with slightly more than half the displacement of the GM L87 V8.- Bionic_ManExplorer
With an *
This is for 150/1500. And it says "V8 Towing", so it would imply that it doesn't compare to an EcoBoost, which can tow up to 13,200 pounds.
I'm not saying it is a bad engine. But it is pretty dated now.
44,071 PostsLatest Activity: Aug 09, 2026
