ajriding
Aug 30, 2019Explorer II
StirCrazy wrote:
the other thought was a used bigfoot or northern light but I am now sure how hard that would be to work on.
Steve
If you have the money for those then yes. Either is nice. They look the same to me.
I have a fiberglass TC as well. How hard to work on? Not any harder.
You will not be accessing the walls from the outside ever, unless you want to do fiberglass repair and can match a gel coat.
Unless you crash it the roof and walls should be trouble free for the life of it.
Fiberglass campers do tend to get sagging roofs.
Keep them waxed.
If you are looking to fit in tight spaces (I thought you meant narrow dirt roads covered with low trees), then a TC is not much smaller than any class C.
If you want a full size TC, then the two you mentioned would be what I would look for, consider nothing elseā¦
