RandMJacobs
Mar 02, 2021Explorer
NRALIFR wrote:
There’s a GFCI outlet on my 1121 over the galley sink, under the overhead cabinet. When that trips, it affects other outlets as well.
I’ll check the CB on my generator (Generac 36LP) for how it operates. Do try plugging into an external AC power source to eliminate the generator and the CB’s on the generator. I take it the generator starts and runs, but there is no AC output?
Your 1121 would have come from Lance with a GFCI outlet above the sink, but of course it could have been replaced or eliminated by now. You should NOT have an automatic transfer switch (ATS) on your camper as Lance wasn’t using those then. Your shore power cord should be plugged into a 30 amp RV receptacle in the cord storage area. That receptacle and the shore power cord plug is another possible failure point.
Great response. My wife says I have to wait until a "Godly hour" before I can test things out, however. Wives, right?!!!!!
Anyway, yes, it appears there IS a GFCI above the sink, so will try that out. Also, and more important, I should have remembered that I have to replug the shore power into the built in receptacle in the same compartment. But again, can't check yet, but pretty sure without that plugged in, I shouldn't have had any reason to expect the generator to provide any power to the TC. So, pretty hopeful once I can power on the generator, that my troubles will be gone. I will post when I have it up and running. Much thanks for the suggestions/reminders.
