RandMJacobs
Mar 02, 2021Explorer
NRALIFR wrote:
I just checked the operation of the CB on the generator, and yes, it does make a definite “click” sound, and has a noticeable detent feel to it when you operate it.
Unfortunately, this generator has been out of production for several years now, and Generac doesn’t even make built-in RV generators any longer. It’s been a few years since I’ve needed a part for mine, but the supply of new, “Generac unique” parts was drying up. Used and refurbed parts may have to be located.
It’s difficult to impossible to find the manuals for my generator on Generac’s site, but here’s a link to the parts breakdown for a 941-1, which is what mine is.
https://generac.ordertree.com/catalog/partslist/group/group_id/233167/
Here’s a link to the service manual (which doesn’t include part numbers) at generator-parts.com
http://www.generator-parts.com/manuals/generac-rv/0D1752.pdf
Here’s a link to the parts breakdown at jackssmallengines.com
According to this, the CB part number is 0A8592, but when I add one to the shopping cart to buy it says it’s out of stock. That’s a two-pole, 15A CB, and I doubt it’s a Generac unique part, so you may be able to remove it and find the manufacturer info printed on it.
https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/generac-engine-part/generator/00941-1/control-panel
Jacks is where I’ve purchased parts most recently. Maybe give them a call.
First off, now that it IS finally a "Godly hour", I've had a chance to put your suggestions into use...and we have power. As I suspected once you suggested it, the culprit was not plugging the shore power back into the Lance's receptacle. And, since I left the generator's circuit breaker in the off position, until I returned it to "on", I still didn't have power, so that CB appears to be functioning...whether it will trip if it needs to, is to figure out on another day. For now, we are running on generator power and recharging batteries. So, huzzah! And thanks...both for the suggestions AND the links. I'll be checking those out shortly.
