Plumber101010's avatar
Jan 07, 2015
Loud water pump and possible solution?
Travel Trailer 32 ft. Newbie. So loud water pump kicks on every time you open any water source. Being a master repair plumber for 35 years, I cant help but feel adding a small, bladder / resorvoire tank will solve that problem AND give added volume at the few rare times more than one faucet is needed.
Fact, I'm not sure why not used all the time on this type setup? A tank will allow running of water WITHOUT the pump kicking on and off in sync with usage. Plus its nice having a reserve incase water pump or water source goes out.
Seeing as how it's under the sink, only a 1 gallon would fit, but if I remove the shelf, a 5 gallon would fit and that would be just dandy and wonderful. Pump would seldom kick on.
So why am I here if I am a know it all NEWBIE :)))). Well....not sure these little baby pumps can build ANY pressure at all? Hoping someone here would know. They would need around 30 psi, 40-50 perfect.
