minimalcamper
Apr 23, 2019Explorer
Thanks all. I think the hand pump is going way too far for me personally, and that just going from 2.9 GPM to 1.2 GPM is enough to minimize water use and reduce amps. As far as other recommendations, in the future I might consider an accumulator if it seems reasonable, as I like the idea of the pump not needing to run when I run water after my 1 year old goes to sleep. Don't think I will pursue the DC motor speed control option, but good to know it exists.
I did go ahead and order the lower flow Seaflo pump at 1.2 GPM / 35 PSI. After installing it and using it a little I will repost.. I do expect that even this lower flow pump could result in a little splashing at the sink due to the shallowness of the sink and the fact that the pressure will probably still be fairly decent. Simply an issue with not opening valve all the way, but we'll see after the install and make a final assessment.
^ TxGearhead - Yes it is a conventional looking faucet. I might look at aerator options or replacement sinks down the line.
^ Travels with Yoly - Your feedback assures me that lower flow is probably the better decision for me, since I'll use less amps, probably be quieter, and still get adequate flow for my single fixture. I watched your video with the sink flow demonstration, thank you. The one I bought is probably VERY similar to the one you linked to. Seaflow Pump I Bought
44,056 PostsLatest Activity: Jan 12, 2020
