- Ron3rdExplorer IIIVery good info in the links posted above and I would explore that aspect.
I converted my Weber by removing the regulator and have had zero problems and the grill gets plenty hot. Here's how I did mine to run of the quick connect hose on our new Rockwood:
WEBER CONVERSION - LynnandCarolExploreryes, double regulated!
- myredracerExplorer IIdouble post
- myredracerExplorer IIIf the Weber has a regulator on it, you need to remove and come up with the right fittings so the hose will connect directly to the BBQ. That's what we've done and it works great. Two regulators in series don't work that well.
- Aluminum_SidingExplorerThe BTUs may not be set for it. Those little cans have a lot of pressure.
- camperforlifeExplorerThis link is the best answer and solution to your problem that I've run across.
44,070 PostsLatest Activity: Jul 26, 2026
