ib516
Feb 11, 2015Explorer II
Lower hp ratings in HD trucks
I know it has been discussed here before, but I found a real answer so thought I'd bring it up.
Example, the Ford 6.2L V8 and the RAM 6.4L Hemi are both rated for less power when the truck's GVWR exceeds 10K #.
Ram 6.4L Hemi in a 2500 - 410 hp, in a 3500 Megacab - 367 hp
Ford 6.2L V8 in an F250 - 385 hp, in an F350 DRW - 316 hp
The question is WHY?
Most will answer that it's due to different engine calibrations for more durability. That's incorrect.
The real reason is NOISE and the EPA.
I was following this thread called: "Ask the engineer" where the engineer that designed Ford's 6.2L V8 (Mike - V8 Ford) was answering questions.
Here's a link to the page where this question is addressed.
LINK
His response is broken into a few posts as people ask clarifying questions. I'll copy and paste here.
"Originally Posted by boatwon
Hey Mike,
What is the difference in the 6.2 for a dually application? Or is it same engine at a lower RPM rating? Will it still rev to 6000 RPM? Same power through whole range or different programing?
thanks, Doug"
Reply: "Same engine, same calibration, same everything, except that power is declared at a lower speed, resulting in a lower power rating."
Quote:
Originally Posted by Crazy001 View Post
It's rated at a different RPM.
If I remember right it's rated at the torque peak rather than the HP peak.
So the same engine will perform the exact same way, but for reasons I don't understand rated HP is different from peak HP.
As an example, consider your van. It makes 410 ft-lbs @ 2,700 RPMs. If it were rated the same way the new engines are in dually applications it would NOT be referred to as a 265 HP engine. It would be a 210 HP engine(410 x 2,700)/5252.
Same engine, same peak HP, just rated differently.
Reply: The power and torque for the over 10k GVWR Superduty 6.2L is rated at 4200 rpm (hence the lower power number versus the F250). The engine still redlines at 6000 rpm.
On the F250 the peak horsepower is at 5500rpm and the peak torque at 4500 rpm.
Thanks for the correction, Mike!
Sorry to confuse things, Bill. I read about this awhile ago and I thought it was at the torque peak. Looking back I'm seeing 316 HP and 397 TQ, both rated at 4,179 RPMs.
So not quite torque peak, but both numbers are rated at the same RPM for some reason. Why is this?
__________________
Tom
Reply:
Compliance with EPA noise requirement
LINK
Hey Mike,
thanks, Doug"
__________________
Tom
Reply:
