Barry_W
Jun 11, 2023Explorer
Lp gas
I have a host cascade with the quick attach gas valve and quick connect. I am not able to to get gas flow to my cooking equipment. Would anyone here have suggestions as to what might be going on. All...
MORSNOW wrote:One reason I installed a high pressure quick connect. Uses the BBQ regulator and I can connect multiple propane devices. Think BBQ, fire pit etc.
You have to remove the regulators from the appliances (grill, griddle, etc) you are connecting to the quick connect. The gas is already regulated down at the tank to camper connection, if your grill also has a regulator, it will be double regulated and not receive enough gas flow.
