anutami's avatar
anutami
Explorer III
Feb 06, 2014
Maggie Rack popularity
Any thought on the popularity of the maggie rack roof rack system? Lance has used it for quite some time and it seems adventurer is getting in on the action. I installed on my 2012 wolf creek after driving to the topline factory in LA and picking up. I ordered my second wolf creek 850 withouth the pathetic little joke of a roof rack they are installing and planning on installing a second maggie rack system. Why is northwwod mfg so far behind the times with their roof rack storage sysyems? Is anyone from northwood mfg actually monitoring this forum?
My install off the maggie roof rack
How it held up rolling off my truck, the drivers side rear came loose.
Side note, I used the 3m high bond tape to install the solar panel andit did not move at all!!! I did not use it on the maggie roofrack.
  • I had one installed by Truck Camper Warehouse before we took delivery of our Wolf Creek 2 months ago. I didn't want the shower-curtain rod luggage rack, either. They did a great job. They used some long rails, extending past my fridge vent a bit.
    TCW did me a favor and installed an extra pair of nuts in the rails' slots before the rails were mounted. That gives me the option of bolting a third cross bar to the existing rails. I pursued that option earlier this week, contacting TopLine Manufacturing by phone. They told me they don't sell parts (a pair of cross bar mounts and an 8' cross bar for a third assembly). Only kits. I figured I'd look around for other options, a little dismayed by their customer suppport. What if I bent a bar and needed a replacement? Anyway, I emailed PerryCraft, who makes the Sport Quest rack system, about a pair of uprights and a bar. Their uprights should bolt directly into the spare set of nuts TCW installed. However, they only have 70" bars. So, I'll get a pair of their uprights and order an 8', 20mmX30mm bar from ETrailer or somewhere.
    I definetly like the rails, but, what the heck? Help a man out. Jeez.
  • Ok I will be the first!!!!!! How did you roll the camper off the truck??????
  • I find that the only good thing about Northwoods roof rack is that it gives me something to grab onto to help me get up on the roof when I climb the ladder. Thats the only benefit I can come up with. A grab handle located in the right place would be better.
  • RoyB's avatar
    RoyB
    Explorer III
    I too am in the planning stage for mounting three 120WATT size solar panels on my off-road POPUP roof.
    I will want the two front 120WATT panels to have quick disconnects so that I may move them to remote ground locations when necessary to keep in the high sun when I need to.
    My off-road trailer roof may also get overloaded when raising with its electric motor with all three panels already installed on the roof so I may have to mount the two front 120WATT Solar Panels in place after I have the roof raised and locked down...
    Your "MAGGIE RACK" idea may work out for me as well...
    Thanks for the photos - nice clean layout...
    Roy Ken
  • Can you elaborate on how you attached the solar panel with the VHB tape?
    I am in the process of moving a solar system from my older Northstar camper to my new AF 990 and may consider using the tape instead of screwing the panel down.
