ScottG
Apr 10, 2015Nomad
Yes, only those two.
I don't remember which is which...
If you have an ohm meter then the one that has continuity to all the fuse holders is the positive. So pull the fuses out and see which block is connected to one side of the fuse holders. Dont check with the fuses in or it may give you a false reading.
You could also look at the battery and see what color wire is connected to the pos and neg terminals and then look for that wire at the 2 blocks on the converter fuse block.
44,030 PostsLatest Activity: Feb 06, 2025
