jstickley's avatar
jstickley
Magnetek 6300 direct dc wiring
How do i directly wire a battery to the DC side of a Magnetek 6300 power converter? I have no where where i can use the AC side, but want to use the DC side, in conjuction with the solar panels I have. Right now I am using an inverter off the battery, for lighting, etc.. But would really like the trailers already installed lights to work, among other things in the trailer.
I cannot find any information on this on the web, and the one "manual" is about worthless in explaining this.
Thanks in advance!
  • From the information you've provided, no, it makes no sense.
  • Ok... Maybe I should post a picture.. The AC side has no breakers. I am hoping to just be able to power the DC side, and not mess with the AC side.. Make any sense?
  • If your not using the AC side of a Magtek 6300 then there's not reason to hook up the other side.
    Are you just wanting to use the fuse block? If so then just hook up to the battery connection of the Magtek.
  • Very confusing question. I have no idea what you're asking.
