The only reason we ended up with a Passport was it had a layout we really liked. Just about one year and a half dozen trips in it. Ours is pretty much the same as what everyone around here says is industry standard for mass produced campers. We had the usual list of little issues - loose trim, stripped off window operating handle , a screen that didn't fit right..... Probably the worst problem was the black tank flush vacuum breaker valve leaked a gallon of water on the bathroom floor the first time I used it - no harm done since I caught it fast. The dealer acted as though they had never heard of this valve, but I showed it to them and let them get it resolved with Keystone.
EDIT: The closed belly and heat is only good for temps dipping a little bellow freezing at night. We did one fall trip when the forecast was for just over freezing during the day and dipping into teens at night. The first day was good and at night it hit 15*F we where fine. The second night it went to 7*F, the heat ran continuously for 12 hrs with interior temp about 45 at the worst part (like 2 to 6 AM) and the water system froze....never doing that again!
