That’s a very common problem on Diesel engines that were manufactured from about 2007-2010. They typically had diesel particulate filters (DPF), but did not use diesel exhaust fluid (DEF). They relied heavily on exhaust gas recirculation (EGR) to control oxides of nitrogen (NOx), and as such, cleaned or regened the DPF frequently. Sometimes as often as every 75 miles or so.
Most, but not all, of the Diesel engines of that era started the regen process by over fueling the engine on one or more cylinders, causing unburned fuel to flow into the exhaust where it would then be ignited inside the DPF. That over fueling also caused fuel to get past the rings into the crankcase, and is what resulted in the engine “making oil”.
I had one of those engines in a 2010 F450, the 6.4 L Powerstroke. I absolutely loved everything about that truck, at least initially. I learned to absolutely hate the engine though. I owned it for a little more than three years, and I always drained out about a quart more oil than I put in. Top-end valve train failures were an issue with those engines, though I never experienced that myself.
Ford had a TSB for the 6.4’s to check for excessive fuel in the oil that involved pulling the dipstick, wiping it clean, then replacing it just to the point where the plastic pull ring at the top of the dipstick started. That was at least an inch higher than if you fully seated it in the dipstick tube. As long as the oil level wasn’t higher than the top line on the dipstick, all was supposedly good and there was nothing to worry about.
I got rid of that truck before it caused me much financial pain.
