StirCrazy
Jul 06, 2023Moderator
KansasKen wrote:
thanks for posting this, I had not given thought to weather the LI-ion batteries would start my Onan. I was just about to do a conversion from 4 100ah AGMs to 4 100ah Li-ions so the timing of this post saved me from the same situation. I’ve never run the Onan more than a few minutes, so the 6ah solution will not be a problem for me. I think your solution would be a great idea to copy.
they will, you just have to have enough current capability to meet the requirements of your genny for amperage. one LFP depending on the installed BMS may not put out enough amperage, if that is the case then you need to have more in parallel to increase the amperage available for starting.
