tcgg's avatar
tcgg
Manual Awning Question/Help
When the manual awning is fully pulled away from TT and the short slide arms/rails are extended now ready to be raised up on each side I have difficulty in pushing the arm/rails up. I do not extend one side fully then the other. Just extend a little on one side then the other. It is still hard to push the arms/rails up to the fullest even at short extensions. The rails appear to be free of dirt/grim. Can a lubricant be sprayed on them to make it slide up/out easier? Any suggestions appreciated on how to extend them with ease even if a lubricant should not be used. Thanks in advance.
