Assume this is a very...similar?...camper to our EC850. You can see the COG is directly above our axle (BTW GM shows a "range" for COG centered around the axle in their Camper Loading Guide).
You can also see our truck is a (06) SB.
Anyway, EC says the COG has shifted FORWARD 1" with the 2015 full wall slide...so I am confused why you are clearly showing the COG behind the rear axle.
How long is your bed?
I also took off the "guides" that EC provides...they keep the camper ~3" off the bed wall. This allows me to load forward a ~ 2" which helps put more on the front axle.
FYI; I did add Supersprings and rear anti-sway bar which both helped a lot.
The truck handles fine, we have done 5k+ miles this summer with the new camper...
We pretty much always leave with a full h20 tank (49 gals). Love the EC850; the floor space, inside and outside storage, and large tanks are incredible for a SB camper.
Very pleased so far...our 1 yr anniversary with it this month.
Agree with kohldad...pictures can skew things...and you really will need to visit the scales to know for sure.
Do tell about the "mystery" camper in your pic...
