mrkoje
Aug 06, 2013Explorer
Svichera wrote:
The marker lights can be turned on quite easily. All you need to do is jump the battery charging pin with the running light pin on the trailer pigtail. It is the top two on the trailer pigtail. I do it all the time while camping. I don't recommend doing it if you are dry camping. It can run your battery down.
What is the reasoning behind doing it though other than you can?
44,071 PostsLatest Activity: Aug 23, 2026
