miyzfrider
Aug 11, 2013Explorer
Learjet wrote:
I used a spare fuse on the DC panel, ran hot to switch, ran wire from switch and hooked to running lights. Doesn't interfere with the the normal path from the truck.
Where did you tie into the running lights exactly? Did you run a wire from the switch to the closest running light or all the way to the front of the TT where they tie into the trailer connector? I assume the lights are all hooked in series, so if you tie into one, they all light. I've looked at my panel, and I have a spare fuse location on the DC section, and also an open switch location on the control center. I think having them tied in inside to a switch would be much nicer.
44,071 PostsLatest Activity: Aug 16, 2026
