Learjet
Aug 11, 2013Explorer
miyzfrider wrote:
Where did you tie into the running lights exactly? Did you run a wire from the switch to the closest running light or all the way to the front of the TT where they tie into the trailer connector? I assume the lights are all hooked in series, so if you tie into one, they all light. .
Any part of of the running light circuit will do, and they are in parellel, not series. I know tech talk. Yes, I ran a wire to the easy light... and closest I could find.
Also, you only need to run the hot (+) wire, since the ground is always present.
44,071 PostsLatest Activity: Aug 16, 2026
