2oldman wrote:
palmwhit wrote:
Usually the few times we experience this I've got the heat on, but blew it this time.... Turned on the furnace to 55 where it has now been for 3 days.
Not sure I understand this part. You blew it, meaning the heat's been set to 55 for 3 days, but it's producing no heat?
If so, your water pump is frozen. And, if no shore power, your batteries are probably dead.
I blew it by not having the heat on to prevent the possible freezing of water lines! The furnace has now been on for 3 days and working fine! I have AC and DC power in working condition. Sorry it wasn't more clear. The pump may have frozen before the furnace was turned on, but that doesn't explain (to me) why the monitor panel isn't functioning unless there is a unknown fuse that links the panel to the switches.
