mike-s
Oct 10, 2017Explorer II
CapriRacer wrote:Wheels also have max pressure ratings. For example, Dexstar 017-324-xx wheels are rated for a max of 1870 lbs and 50 psi.
It is my understanding the wheels fail due to overload, not overinflation. Since the wheels will be carrying the same load, there isn't a problem with using tires that uses more inflation pressure.
And, when going over 65 psi, high pressure valve stems are required.
44,066 PostsLatest Activity: Mar 14, 2015
