Ron3rd's avatar
Ron3rd
Explorer III
Dec 12, 2017
Max PSI rating on Trailer Wheels?
My trailer's Alloy wheels are 15 x 6, 5-lug. The load rating stamped on them is 2150 lbs. It came with 225-75-15, load range C tires, which run 50 psi. These tires are are marginal IMO for the trailer which has a gross weight of about 8600 lbs.
When I replace the tires, I'd like to go with load range D tires that run at 70 psi. How do I know from the specs on the wheel if they can handle the higher psi?
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    JIMNLIN wrote:
    A wheel with a 2150 lb capacity is limited to 50 psi which corresponds with a C tire.
    Now if the 15" wheel had a 2680 lb or higher load rating then the 65 psi D tire will work.
    A 6 lug 15" wheel with a 2830 lb rating will handle a load E tire at 80 psi.
    A 8600 lb TT may have close to 1000 lbs on the tow vehicle leaving 7600 ln on the trailers axles or 1900 lb on the wheels. Now add a good 15 % reserve capacity = 2185 lb.
    Let your trailers axle ratings dictate tire and wheel selections and figure a 10-15 percent reserve above them.
    That's the answer I was looking for!
  • A wheel with a 2150 lb capacity is limited to 50 psi which corresponds with a C tire.
  • If upgrading tires (rubber), have a serious look @ ST235/80R16. Might be worth the +1 upgrade on both rubber and rims / assume available space within the fender well... Especially if you plan to keep your RV for many more years...
  • I agree with a tire upgrade and went from LR C to LR D, highest possible I found for the 14 inch tires on my TT but would have Es if available. Ds take 65 psi max while Es should be inflated to 80 cold.
    they are good to the load specified. so if the load range D are 2150 lbs or less at max pressure you are good to go.
    It's common that the 5 lug wheels are good for LRD and the 6 lug to LRE.
    If they are steel wheels they sometimes have a max pressure stamped on the as well.
  • Your rims will be fine with the 65psi that LR D tires take. I change from C to E ply rating on my trailers, no problems in 20 years or so.
