- dbblsExplorerThe bottom line, Ford is still the best selling pickup.
- notevenExplorer IIIIf these tests included the climbing and downgrade test run for 14 hours, then published fuel used, the measured brake wear after the test, and calculated to $ cost over distance towed - it might mean something to someone spending this kind of $ on a pickup truck.
No wait - "towing" is all about who can cane their truck to the top of the hill the fastest - - FordloverExplorer
Cummins12V98 wrote:
Sure nice they do mention the RAM had the 4:10's but never mention what the 450 had for gears. Ya think lower gears may get to the top first?
But the bottom line is the Medium Duty RAM will be doing it much longer than the Ford.
Pretty sad that Ford has to compare their 450 to RAM's 3500.
Well of course it will be doing it much longer, it's going a lot slower. :B
just kidding. Honestly I would have expected the 450 to be slower, since it likely weighs a lot more than the Ram, and both were pulling well within capacity and equal weight. But I did notice they didn't list rear gears on the 450. - Cummins12V98Explorer IIISure nice they do mention the RAM had the 4:10's but never mention what the 450 had for gears. Ya think lower gears may get to the top first?
Pretty sad that Ford has to compare their 450 to RAM's 3500. - wcjeepExplorerWhat does Ford use for an exhaust brake? Momentum is easy. Stopping with hot brakes on a descent while loaded is dangerous. With my exhaust brake I've measured my brake pad temps after exciting the freeway after a hill descent. Pads are usually 10deg warmer than ambient temp.
4500 vs 3500 also makes no sense. - MTPockets1ExplorerI believe Ford and Ram are fine trucks and the one that you pick is the right truck....... As long as it's not a GMC.
- TerryallanExplorer II
larry barnhart wrote:
the world is sucking at this time so to me trucks are not important
chevman
Yep, a lot going on. It's in the hands of God - larry_barnhartExplorerthe world is sucking at this time so to me trucks are not important
chevman - blofgrenExplorerI'll consider the Ford when it is still running like new after 300k plus miles with minimal engine work. Until then I'll keep my Ram thanks. Not only do I love it but my entire family does!
And remember this is coming from a guy who owned 3 Fords over the last 20 years including both the 7.3L and 6.0L diesels! - Turtle_n_PeepsExplorerI heard Ford put there F350 against the Chevy Luv. The F350 won. :B
44,056 PostsLatest Activity: Nov 19, 2013
