kaydeejay
Jun 13, 2015Explorer
kw/00 wrote:The glove box sticker quoting max camper weight is what is left of the truck payload after subtracting 150# for each available seat.
I have seen just a small amount of campers for a 1/2 ton truck out there. They have a pop up top and have canvas. I agree with the others about the camper in question. Keep ur search going for a lighter unit. Now the glove box number confuse me as well. My truck says its payload it 2997, however the glove box sticker is slightly less then that.. so I think the glove box number is the safety margin for a slide in truck camper since its so top heavy but I could be wrong. Either way I would not want to exceed the number listed in my glove box for the slide in camper.
You can add 150# to that Camper rating for each empty seat in the truck.
But OP, you are NOT going to get anywhere near capacity for that camper, which is going to be a lot more than 1500# by the time you are ready to camp!!!
Also, the true payload for your truck may or may not be 1700#. Take a look on your driver's door pillar. There is a yellow/black Tire loading info label with a number "Weight of occupants and cargo must not exceed XXXX#"
"XXXX" is the rating for YOUR truck, "as built".
With a "Reserve Capacity" (max camper weight) of 774# I rather suspect your actual payload is going to be closer to 1524# (that being 774 plus 5 x 150).
44,056 PostsLatest Activity: May 04, 2014
