Atlee wrote:
As mentioned in my reply to Coolbreeze, Sendek is the manufacturer.  Specs as follows.  Model # TO7-45545GM Gray Machined.  Size 14" x 5.5"; Bolt Circle 5/4.50; Offset +0; Center Bore 3.19; Load Rating = 1900# @ 60psi
gmw photos wrote:
What is the brand of your rims ?
I think if you do some research on that, you may find that your Sendel wheels are load limited to 1900 pounds, but are not strictly pressure limited to 60 psi.
When checking to see if I could use 65 psi load range D tires on my Sendel wheels, I got three separate emails from Sendel, Tredit ( the Sendel wholesaler ) and from Cruiser RV stating it was safe to use 65 psi in my wheels ( same size and rating as yours ).
Sendel also states all their wheels are built to SAE J2530 standards, which refer us further to SAE J328.  As I read those standards for test procedure, these wheels would have to be rated for 65 psi, which corroborates what I got from the wheel manufacturer ( importer actually ), wholesaler and RV company.
Was good enough for me.  I put high pressure valve stems in, and inflate my load range D LT tires to 65 psi and go camping.
