colliehauler
May 10, 2015Explorer III
Turtle n Peeps wrote:So with the higher cost of straight gas over E-10 against 4% gain in mileage it's about no difference money wise?agesilaus wrote:oldmattb wrote:
Toyota Echo driving from Houston to Atlanta and back several times, I noticed a drop in mileage from 43 highway to 39 highway. I came to realize it was the alcohol in the gas. In this case, ten percent alcohol reduced mileage by ten percent.
Matt B
That shows the danger of informal testing. You are saying that you got no energy from that 10% ethanol. Other factors like vehicle loading, driving style and wind might also affect the results.
This^^^^^.
With modern engines computers always keep fuel at the best stoichiometry ratio for the fuel.
For gasoline that is 14.7 to 1.
For ethanol it's 9.0 to 1.
For methanol it's 6.2 to 1.
For E85 it's right at 9.5 to 1.
Anytime you mix a fuel with less energy with one that has more energy you will end up with a fuel that get less MPG.
With E10 that is right at 3 to 4% less miles / gallon.
The good thing about E fuels is they will make more power than straight gasoline...........and that makes me :)
200 miles with 21 gallons of e-10 =9.52mpg vs .84 more mpg for regular gas or 10.36?
44,071 PostsLatest Activity: Aug 16, 2026
