jake2250
Jun 10, 2016Explorer
That is an awesome truck! Some good info for you! Especially the HEI distributor, I had a 1973 GMC 3/4 ton 4x4 with the 350, I did and HEI conversion from Mallory in the late 80s, It was the best ignition upgrade I have ever installed, It was a drop in unit that replaced the points and condenser, It was basically a laser light with a slotted wheel that replaced the points, then it had a control box that I mounted on the inner wheel well. Never had a distributor issue after that and it had a way better spark!
That is going to be one heck of an RV! A cab over camper will make that ride like a Cadillac!
My truck also had two 25 gallon tanks and I sure miss that,, as soon as one was at a 1/4, you just flip a switch to the full one and kept on motoring!
Very solid trick, I believe those had DANA 70 rears in them,, bullet proof!
Good luck with your rebuild and yes please post picts of the adventure!!
Sure miss my old truck, I'd buy it back in a heart beat if I could!!
44,025 PostsLatest Activity: Feb 18, 2025
