path1
Aug 21, 2014Explorer
Mercon and Mercon 5
From 2003 owners manual...
"Some transmission fluids may be labeled as dual usage, such as
MERCON and MERCON V. These dual usage fluids are not to be used
in an automatic transmission that requires use of the MERCON type
fluid. However, these dual usage fluids may be used in transmissions that require the MERCON V type fluid.
MERCON, MERCON V and MERCON SP are not
interchangeable. DO NOT mix MERCON, MERCON V and
MERCON SP. Use of dual usage fluids in an automatic
transmission application requiring MERCON SP may cause
transmission damage. Use of a transmission fluid other than the
recommended fluid may cause transmission damage."
My dip stick say Mercon. Engine is 5.4 gasser with a 4r100 trans, that I believe has been re-built.
I use Mercon V. Back of bottle basically says..good for both.
What am I missing? Maybe 2003 info (older and outdated) and maybe newer stuff on market now?
Thanks
Thanks
