Wrace
Apr 01, 2014Explorer
Mice block for power cord door?
We were getting mice in the TT, they were entering through the slot in the power cord door. The TT stays plugged in at our seasonal spot. I put some steel wool in to close up the small gap that exists in the slot when the cord is running through it. This took care of the mice problem but the steel wool of course rusts and discolors the white plastic door. I’m wondering if there is another material that will fill that slot and repel the mice?
Long term I will remove the permanently attached OEM cord and put in one of those outlets in the side of the TT and use a detachable cord as this would be much more convenient for our set-up, but until then I need to keep the mice from coming through that slot.
Bonus question. When I went to remove the plastic cover over the propane tanks at the end of last season there was a mouse standing on one of the tanks frozen in fear that I had just exposed his little world. On the other tank was a nest. What can I put on top of the tanks to repel the mice from building a nest here?
Thanks
Thanks
