What is the best option to keep mice out of TT. Do the peppermint sprays really work. I don't want to use moth balls or anything toxic. I do have the bottom sealed pretty good but a mouse can always ...
As stated. Close all entry points. If you do see signs that mice or rats are getting in try to find the entry point quickly. I have used sticky pads to catch them. Much higher catch rate that traps. I have had my truck damaged from rodents two different times now. Finally found the entry point. Good luck. And mothballs do nothing but stink.
