ROBERTSUNRUS
Jun 10, 2016Explorer
Fordlover wrote:
I'd like to see more than ~3 seconds of partial shots of the GM bed (and why a second or two of the outside ?WTF? other than to avoid more shots of the damage). Tricky photog work does not impress me.
:) Hi, exactly. All trickery from the liars at GM. I saw rounded corners on the GM load, but you can't see the Ford load. Also did you notice there were two tool boxes. The one used in the Ford had the bottom re-inforced with plate steel. You could see in the video how much harder the (heavier) box hit in the Ford. Also how did concrete blocks make such sharp cuts into the Ford bed? This is all BS.
