Turtle_n_Peeps's avatar
Sep 28, 2016
Mistaken ideas about how a diesel engine works
I've seen a lot of grumbling as of late about the power output of new diesel engines.
These same people complain and ask why the manufactures have to run the power up so much and why don't they work on fuel economy.
The answer is simple: A diesel engines power output is in direct proportion to the amount of fuel it burns.
In other words: If you have a 500 HP diesel pickup and you only use 100 HP, it will only burn 100 HP worth of fuel. If you're WOT, you will burn 500 HP worth of fuel.
Case in point: A friend has a Cummins that is bombed. Intake, twin snails, studs, exhaust, cam and a few other goodies. Dyno'ed at 525 to the rear wheels. This truck will pull down 23 MPG on the hiway all day long at 65 MPH. Why? Because he is only running about 60 HP worth of fuel through it at that speed and load. Now if he puts a heavy trailer on the tail and tries to climb a 12% hill at 75 MPH; guess what? He will burn 525 HP worth of fuel doing it.
Another case in point: I keep books on all of my fuel stops over the years when I'm on vacation.
I have a 93 200 HP 6.5 diesel and an 06 360 HP Dmax diesel. I have pulled my TT many years with both. The 6.5 would get 12 MPG pulling the TT. My Dmax gets........are you ready..........12 MPG pulling the same trailer.
The Dmax gets a little bit better mileage because it has a 6 speed tranny where the 6.5 has a 4 speed. The 6.5 gets a little bit better fuel mileage because it can only flow 200 HP worth of fuel at WOT where the Dmax can burn 360 worth of fuel. So all in all, over all the years they both average 12 MPG in 10's of thousands of miles.
So, if you buy a new diesel stop bitchin about the HP and mileage deal. You want better mileage with your new 440 HP pickup? Use only 275 or 300 or 325 HP worth of fuel. To do this you are going to have to slow down; even on the hills.
Remember; if you only flow 300 HP worth of fuel you will only burn 300 HP worth of diesel. IOW's "you" are in control of how much fuel your new high HP diesel burns, not the manufacture! :)
