jserr68594
Nov 30, 2013Explorer
Modded my RV, Added Fireplace, Surround Sound, & LCD TV.
Hello,
I recently did some modifications to my 2005 Keystone Laredo 308GR that I thought I would share.
I did not like the location of the original CRT TV as it was too low. I wanted to move the TV up to where the cabinet doors were (Pictured below). I had to build a frame to mount the TV to. I built the frame and secured it well. I then found paneling that matched the camper and covered the frame with it. I also found some oak colored trim that was a good match as well. I trimmed around the paneling with it as well as all of the openings in the cabinet. This not only covered prior screw holes, but also dressed it up really nice! The TV is on a full-motion mount and can be moved and tilted every-which way. I also installed a new Sony 5.1 Surround Sound system with sub woofer.
Once I did this I had a huge hole where the TV used to be. I decided to build a frame and install a custom electric fire place. I also moved the center channel speaker to the space below the fireplace for a custom look. The fire place can put out heat or just be on without heat for the visual effect.
Here are pictures of the project:
Before:
Frame Building:
Frame behind TV, which is now trimmed out with mathcing paneling. Looks factory!
Paneling and oak trim behind the TV:
Showing how the TV tilts and Angles:
Final Result:
Surround Sound Speakers:
Before:
Frame Building:
Final Result:
