bighatnohorse's avatar
bighatnohorse
Explorer II
Sep 11, 2018
Modification help needed for gutter
The side awning was badly mounted on my camper. The mounting bracket was installed over the rain gutter.
The bracket screws went through the gutter into the camper!
I tried caulking around the screws but don't trust it to not weep into the camper.
It rained the last few days and now the gutter is holding water dammed up by the screws and caulk.
I drilled a small 3/16-inch weep hole for now to let out the water.
The weep hole is now about 1-inch to the right of the screws.
My thought is to drill a bigger hole but I can't think of how to channel or drain water away from the camper.
Any ideas or suggestions on how to modify or fix this delima are appreciated. . .
Photos:
Close view:
  • I’d probably ask the manufacturer. You could consider marking the lag screw, pulling it, and filing off the threads and putting it back being careful with how much sealant you use.
